syntax for <null>
  • Jul 13, 2022 2:08 PM UTC
  • 430 views
townest
Forum|alt.badge.img+4
What is the FME syntax required to assign a <null> value? Inputting <null> seems to return the string '<null>' and not a bonefide <null> (greyed out FME version). Some fields offer <null> in the drop down, but some do not and require the user to input, such as...
imageThank you.
Tyler
FME WorkBench 2021.0
Best answer by ebygomm
I wouldn't expect null to be possible there since partial replacements are possible, how would null be handled if only part of the string was selected to be replaced?
To replace with null you can use regex or string matching in the NullAttributeMapper, no need for a StringReplacer
  • Jul 13, 2022 2:21 PM UTC
I agree that it doesn't seem possible to assign a null value there. The easiest is probably to use a NullAttributeMapper after the StringReplacer.
Forum|alt.badge.img+54
  • Jul 13, 2022 2:40 PM UTC
townest
  • Jul 13, 2022 2:53 PM UTC
Thx.
