Summing similar attributes without transposing
I have a csv containing >250,000 features and around 50 attributes, which I want to sum based on a common property (e.g. a suffix/preffix in the atribute name). I've done this before on smaller datasets, by using AttributeExploder to transpose the attributes; adding the common feature I want to base the sum on using AttributeValueMapper; aggregating them  and pivoting the output.
However, I think with this many attributes it will be quite memory hungry, is there an alternative approach I could take - possibly using SchemaMapper or something?
Thanks,
Ed
gio
Forum|alt.badge.img+15
  • January 19, 2015
You could attribute explode and  use a regexp to select the similar -attr_name and then create a accumulative attribute and push _attr_value to a variable using a variablesetter.
(You could create a list of the _attr_name and use  a fuzzy comparer to try and automatically match similars)
VariabelRetriever is then Called upon the regexp finding subsequent similar attributes.
You would be progressively summing attributes.
  • January 19, 2015
Hi Gio,
Thanks for your response.
I was hoping to avoid using AttributeExploader as with >250,000 features it'll create >10,000,000 features. I was hoping to be able to map a preffix to each atribute name using SchemaMapper and then aggregate those with the same preffix, without having to transpose the attributes (exploding).
I'm sure there must be a way, that doesn't require generating unecessary features
Ed
gio
  • January 19, 2015
I see.
Well it seems to me you can make a schema, using schemamapper. Then sum them grouping by schemanames and using a aggregator.
Did you not try it yet?
50 attributes is not that much, but you could create the schemamap using regular expression search.
Alternatively maybe you can use a BulkAttribute renamer with RegularExpression Replace. But then you would have to make as many BA's as there are groups..
  • January 20, 2015
Yeah I've got it working with smaller datasets (as explained in the question) - The problem with that though is that you can't aggregate the attributes without transposing them (as far as I can tell anyway?).
gio
  • January 20, 2015
Another possibility might be the use of a listpopulator followed by a listindexer and sum the items on same index (same record bassicaly).
U create a common prefix, the populator crates a list based on this prefix.
Of course then u would have to create a list, wich u also might not want?
  • January 20, 2015
That sounds like a good idea, cheers Gio
