Split attribute values into a list of values
  • Jul 6, 2016 3:56 PM UTC
  • 60 views
Hello,
I'm trying to split a value in an attribute into a list of values:
e.g. Attribute colour has value "red; blue" and I want to split the value by ";" to a list "colour_list{}.colour"
Any ideas? Thanks, Moni
erik_jan
Forum|alt.badge.img+26
  • Jul 6, 2016 3:57 PM UTC
AttributeSplitter is your transformer!
  • Jul 6, 2016 4:43 PM UTC
Hello,
I'm not so sure this transformer is any good. Reason being I don't want to end up with attributes Colour1 (=red), Colour2 (=blue), ... The help page for this transformer suggests that would happen (single line address being split into street, postcode, town...)
In my case, I need one single attribute Colour with a list of values.
erik_jan
  • Jul 6, 2016 4:50 PM UTC
@honkovam That is exactly what the transformer does: create a list from the values using the separator. See attached images:
jdh
Forum|alt.badge.img+41
  • Jul 11, 2016 2:39 PM UTC
The AttributeSplitter as @erik_jan says is the transformer you want to use. It creates a simple list.
_list{0} = red
_list{1} = blue
If however you want a complex list as in your question example, then you would need to use the BulkAttributeRenamer to rename the list as the ListRenamer does not allow for simple list to complex list (though it does the inverse).
