Set Insert into identity columns for all writter types
  • Aug 15, 2014 12:03 PM UTC
  • 83 views
I have SQL Server Non-Spatial writter with ~80 tables (features). How can I set to insert into identity column for all features and Key column, too? It is same column name for all features.
Is there a way to do this, without setting to every feature separately?
Thanks!
Best answer by david_r
if you mean the feature type properties, there is a button on the bottom left "Apply to..." that can be used to update many/all feature types in one go. Very handy.
David
  • Aug 15, 2014 12:12 PM UTC
David
  • Aug 15, 2014 12:23 PM UTC
David,
great thanks. Good answer, and very quick.
I didn't see it. :D
Aleksandar
