Searching all attributes
  • October 31, 2013
  • 7 replies
  • 163 views
dustin
Forum|alt.badge.img+31
I have a set of shapefiles.  For each project, the shapefile names and the attribution names of the shapefiles are different.  I want a workbench to search the attribution of all shapefiles, for a particular word/term.  For discussion purposes, say I want to find the word 'password'.  I don't really need to do anything with the data, I just need to determine if the 'password' exists in the data anywhere.
I've played around with Schema readers and Feature readers, but haven't found a solution yet.  It's almost like I need a way to rename the attribution names to something generic like 'att1', 'att2', 'att3', etc...so that I can run a simple testfilter.  But with the attribution names changing with each dataset, I'm not sure how this would be accomplished.
  • November 1, 2013
One possible way I can think of is to use the TclCaller or the PythonCaller.
This script example for the TclCaller returns 1 when the word "password" exists in attributes of the input feature, otherwise it returns 0. The returned value will be set to an attribute (named "_result" by default).
------ proc findParticularWord {} {   set pattern [format {^(.*\\s)?(%s)(\\s.*)?$} "password"]   foreach name [FME_AttributeNames] {     if {[regexp $pattern [FME_GetAttribute $name]]} {       return 1     }   }   return 0 } ------ If there are 2 or more target words, replace "password" with pipe (|) seperated words. e.g. "foo|bar|foobar".   The same processing can be performed using the PythonCaller with this script. ----- import fmeobjects, re   def findParticularWord(feature):     pattern = '^(.*\\\\s)?(%s)(\\\\s.*)?$' % 'password'     result = 0     for name in feature.getAllAttributeNames():         value = str(feature.getAttribute(name)) # note         if re.match(pattern, value):             result = 1             break     feature.setAttribute('_result', result) ----- Note: If attributes can contain "unicode" type string, "str" function may throw an error saying <UnicodeEncodeError>. See here about this issue: PythonCaller: Use logMessageString Problems with Encoding http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000coj6AAA
Takashi
  • November 1, 2013
David is right. I missed the AttributeExploder.
Thank you for making it notice.
I think it's efficient to use the AttributeExploder with "List" for "Exploding Type" parameter and concatenate the list elements (ListConcatenator) before the StringSearcher. But I noticed that the AttributeExploder doesn't expose the list name, even if I set "List" to "Exploding Type" (FME 2013 SP4, maybe bug?).
If you set "List" type, the AttributeExposer will have to be added to expose the list attribute.
dustin
  • November 1, 2013
When using the AttributeExploder in list mode, I can't access the list afterwards even with an AttributeExposer.  This seems like a bug to me.  I get the same result in FME 2013SP1 build 13450, and FME2012 build 12212.
  • November 1, 2013
I tested in FME 2013 SP4 Build 13547.
If I type manually the following list attribute names in "Attributes to Expose" of the AttributeExposer, can get the expected result. These names are default settings of the AttributeExploder, I didn't edit them.
_attr_list{}._attr_name
_attr_list{}._attr_value
dustin
  • November 1, 2013
Thank you...that worked well.
  • November 1, 2013
If you use the AttributeExploder in List mode, the ListSearchear (Search Type: First regular expression match) can be also used to search attribute having the particular word.
  • November 2, 2013
