Scaling AutoCAD Annotative Block
  • March 4, 2020
  • 172 views
deanhowell
Forum|alt.badge.img+24
Hello again,
We have a DWG that contains blocks that have been drawn in model space and then displayed in paper space using annotative scale. The block in paper space is scaled to the correct size based on the annotative scale but when I send the output to TIFF / PDF the blocks are the wrong size.
TIFF Image above, DWG below.
I know I need to scale the block, probably using the Scaler transformer, but how do I figure out the annotative scale used in the drawing associated with the paper space scale.
There are AutoCAD references to the annotation scale but not sure how to find that scale out in FME as I can't seem to find in through exposing various attributes.
Sample drawing attached :
Best answer by deanhowell
Update 2:
I used an area builder before the spatial relator and that fixed the line issue.
deanhowell
  • March 4, 2020
Update:
I did manage to find the autocad attribute to expose - autocad_viewport_anno_scale_drawing_units and was then able to push that through a scaler transformer but that gave me interesting results at the block is made up of lines and polygons.
deanhowell
  • March 4, 2020
Update 2:
deanhowell
  • March 4, 2020
Update 2:
