Running Workspaces in series - FME Server
pratap
Forum|alt.badge.img+11
Hi All,
I have just started working on FME Server.
Is there any way to execute workspaces in series i.e. executing workbench-2.fmw after completion of workbench-1.fmw
Pratap
lars_de_vries
Forum|alt.badge.img+10
I think the WorkspaceRunner is the way to go.
Otherwise you'll have to do something with the output of workspace-1.fmw calling workspace-2.fmw.
lifalin2016
Forum|alt.badge.img+30
  • April 26, 2018
Actually, with FME Server, you should look at building a master workspace, and have that utilize FMEServerJobSubmitter and FMEServerJobWaiter to run the wanted workspaces/jobs. Otherwise, in desktop, you would indeed need WorkspaceRunner.
  • April 26, 2018
I agree that the FMEServerJobSubmitter is the way to go. You can configure it to wait for the job to complete before it continues, which is probably what you're looking for.
I recommend having a look at the documentation before using the transformer, it's slightly more complex than what meets the eye:
http://docs.safe.com/fme/2018.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/fmeserverjobsubmitter.htm
As a general note: Don't use the WorkspaceRunner on FME Server, it won't work as you expect.
gisuser
Participant
Forum|alt.badge.img+4
  • Participant
  • March 26, 2019
@lifalin2016
If the workspaceRunner could not work, is there any alternative solution to do that?
I have 2 workbenches, I want to run the second one after the first one is completed successfully I
am using FME desktop just.
  • March 26, 2019
gisuser wrote:
@lifalin2016
If you only use FME Desktop then you need to use the WorkspaceRunner.
gisuser
Participant
  • Participant
  • March 26, 2019
I tried it but it could not work, the second workbench does not run
what shall be the issue in that?
  • March 26, 2019
Look in the FME log for errors. Also consider posting it as a separate question, try to give as many details as possible.
pratap
  • March 26, 2019
Hope you are using 2 workspace runners... If yes then post a new question with screenshot of connections between both workspace runners
