Rename MS/SQL table names from MapInfo file names ?
  • February 20, 2018
  • 25 views
lifalin2016
Forum|alt.badge.img+29
I've been given a set of 20+ MapInfo tables, of which most have a period (.) in the file names.
I need to convert these tables into MS/SQL, but this presents a problem, since periods are no-go in MS/SQL, and I need to control the schema.
I'm trying to write using a dynamic writer, but I simply cannot figure out the combination of parameters, that'll allow me to replace the periods with underscores before writing into the database. No matter what I do, I loose the connection to the "schema", and nothing gets converted.
Please help me out. This ought to be a no-brainer, but I'm stumped.
Cheers.
Best answer by david_r
Create a copy of fme_feature_type (e.g. "fixed_fme_feature_type") in which you replace the period with something else.
On the output feature type, specify "fixed_fme_feature_type" as the table name and set "fme_feature_type" as the schema definition name.
  • February 20, 2018
lifalin2016
  • February 21, 2018
I solved it in a different way.
I added a reader of schemas, and did a string replacement in its "fme_feature_type" attribute.
Then I did the same string replacement in the dynamic writer, and pointed its schema input to the schema reader output instead.
That seems to work, although I end up with a small and unwanted table "schema".
I'll try your suggestion for future implementations though. Thanks.
Cheers
lifalin2016
  • February 21, 2018
Hi David,
It seems to work.
But can you explain to me, why <<specify "fixed_fme_feature_type" as the table name>> (i.e. to (a)Value(fixed_fme_feature_type) ) works, where as setting the table name to the expression (a)ReplaceString((a)Value(fme_feature_type),".","_") does not ?
  • February 21, 2018
lifalin2016 wrote:
Hi David,
It seems to work.
That's an excellent question, unfortunately I have no idea why it doesn't work :-)
