Rename an attribute
  • May 20, 2016 2:23 PM UTC
  • 6 replies
  • 141 views
I receive data with standard attribute names but some of the attribute names can vary, is there a way of regardless of what the received attribute name is set it to a value
The table below shows how I might receive data with 1 of 5 different names for Length
So if attribute name is in received column set to the value in the required column
Recievd attribute name Required attribute name LENGTH Length Length Length SEG_LENGTH Length Seg_Length Length Seg_Length Length
erik_jan
Forum|alt.badge.img+26
  • May 20, 2016 2:35 PM UTC
I would use the AttributeCreator creating Length and as a value use the conditional value (if LENGTH Has Value. Elsif Length has value etc).
if attribute name contains "length" or "Length" or "LENGTH" (not sure if this is case sensitive), rename to "Length" in AttributeManager
Forum|alt.badge.img+54
  • May 20, 2016 2:39 PM UTC
You can use a Bulk Attribute Renamer with a regular expression replacement (assuming you don't have any other attributes with the word length in them)
Rename: All Attributes
Action: Regular Expression Replace
Text to Find: .*[L|l][E|e][N|n][G|g][T|t][H|h].*
String: Length
  • May 20, 2016 3:05 PM UTC
Various ways :) The AttributeRenamer.
Note that this screenshot is from FME 2016. If you are using FME 2015, you have to set "No Action" to the Default Value column.
  • May 21, 2016 3:20 PM UTC
Many thanks for the suggestions
The whole idea of asking this question was to see if there was a better way of renaming attributes than I have been doing - which was to
1 - Generate a crc value for each attribute
2 - Explode the attributes
3 - Test for invalid
4 - Value map invalid attribute to correct value
5 - Feature merge all back in to one
I tried a number of the suggestions
BULK ATTRIBUTE RENAMER - works if the input attributes are known.
ATTRIBUTE RENAMER - Thought I was on a winner with one but reading in to itYou cannot use the Attribute Renamer to rename multiple reader feature type attributes with different names to a single writer feature type attribute. Only the last reader feature type attribute would actually be renamed. The transformer does not act as a filter to see if the attribute already exists.
I am very grateful that Safe have introduced the ATTRIBUTE MANAGER. On its own it was not adaptive to different datasets with different attributes, I worked around this by creating a null instance with all the different attributes with both invalid and valid names in an Attribute Manager and feed this in to a second Attribute Manager which is part of the main process - Now no matter what the dataset as long as the attribute name is in the first Attribute Manager the end result is happiness and joy - From 40+ transformers to 4
  • May 21, 2016 10:34 PM UTC
I'm not sure why the AttributeRenamer doesn't work for you. Note that the parameter setting is different between 2015 and 2016, as I mentioned in the previous post. Check these demos.
