Python Shutdown Script works in Desktop but not on Server
  • Aug 10, 2016 3:13 PM UTC
  • 18 replies
  • 195 views
mmccart
Forum|alt.badge.img+33
I have a python shutdown script that works fine in FME Desktop but when I try to run it in FME Server it fails. The logs aren't showing me anything useful.
I think the error may be due to my file path that I am trying to access. If I am trying to access a file via Python on the server, shouldn't I be using: r"//servername/directory/filename.cfg"?
Or should I try something else?
Thanks,
Mark
Best answer by mmccart
Resolved! Thanks to @SteveAtSafe's patience today, we figured out what the issue was.
First off, at some point during my testing, I had copied a version of the .py file to my FME Desktop installation folder (<FME Desktop>\\python\\python27\\). I also was using an old file name for the .py file as well in the directory. Because of this, any changes I was making to my .py file on my C:\\TEMP\\ directory was being ignored.
We fully tested loading the .py and .cfg file up FME Server to RESOURCES>ENGINE>PLUGINS>PYTHON via the Web UI and it ran successfully. We did have to change the path for the .cfg file in the Shutdown Python Script of the workflow to this: C:\\ProgramData\\Safe Software\\FME Server\\resources\\engine\\Plugins\\python\\ for it to work on the server.
Thank you again for everyone's help ( @larry, @david_r and @SteveAtSafe)
-Mark
mmccart
  • Aug 10, 2016 3:33 PM UTC
Note: I put the necessary files in a directory on the FME server.
  • Aug 10, 2016 3:42 PM UTC
If you use a UNC path, make sure that the account running the FME Server Engines service has required permissions to access this folder. If it is the Local System account, try with a local path e.g. C:/.../...
  • Aug 10, 2016 3:46 PM UTC
@larry is right, if you need to access network resources (typically using UNC paths), you will need to run the engines as a domain user, as documented here: https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Running_FME_Server_Engines_Under_Different_Account.htm
If you refer to local files using a drive letter, then this isn't necessary, e.g. "C:/folder/file.ext" should work.
mmccart
  • Aug 10, 2016 4:05 PM UTC
I have confirmed that the account running the FME Server Engine is a local admin on the machine and has full access to the folder in question. I tried putting the files in C:\\Temp\\ on the server and change the necessary code in the shutdown script to reflect that change. I then republished back to FME Server and it still failed.
mmccart
  • Aug 10, 2016 6:06 PM UTC
Can you attach the log file please?
mmccart
  • Aug 10, 2016 6:29 PM UTC
Here it is, though it doesn't provide much insight.
job-1814.txt
  • Aug 10, 2016 7:45 PM UTC
job-1814.txt
In the FME Server web page, go in Manage->Resources and navigate to Logs>engine>current and open the XXX_fmepreocessmonitorengine.log.
Look at the time you ran the workspace and maybe you'll see some error about the END_PYTHON.
I forced a division by zero in the Shutwown script and here's what I see in the XXX_fmepreocessmonitorengine.log:
Wed-10-Aug-2016 03:38:16 PM   INFORM   Thread-14   KEPLER_Engine1   FME_END_PYTHON: evaluating python script from string...
Wed-10-Aug-2016 03:38:16 PM   INFORM   Thread-14   KEPLER_Engine1   Python Exception <ZeroDivisionError>: integer division or modulo by zero
Wed-10-Aug-2016 03:38:16 PM   INFORM   Thread-14   KEPLER_Engine1   Error executing string `a = 1
Wed-10-Aug-2016 03:38:16 PM   INFORM   Thread-14   KEPLER_Engine1   b = 0
Wed-10-Aug-2016 03:38:16 PM   INFORM   Thread-14   KEPLER_Engine1   c = a/b'
Wed-10-Aug-2016 03:38:16 PM   INFORM   Thread-14   KEPLER_Engine1   FME_END_PYTHON failed to execute provided script
mmccart
  • Aug 10, 2016 8:11 PM UTC
@larry / @david_r, after looking at the log, I discovered this line:
Python Exception : No module named overwrite_hosted_features
This is the module I am trying to load. The file is located on the C drive of the FME server and I am using these lines of code to access it:
import sys
sys.path.append(r"C:\\TEMP\\OverwriteScript")from overwrite_hosted_features import run
config_file = r"C:\\TEMP\\OverwriteScript\\overwrite_AVL_Direct.cfg"
run(config_file)
Any suggestions?
  • Aug 11, 2016 7:27 AM UTC
Then it's probably something else. Have a look at the fmeprocessmonitorengine.log file, as described by larry, it should give you all the necessary details for debugging.
  • Aug 11, 2016 12:26 PM UTC
import sys
run(config_file)
Any suggestions?
If you have remote desktop access to your FME Server and are also an administrator on this server, connect to the server and do the following steps (taking care to use your accounts, paths and file names):
- Open a command prompt, go to the fmeengine.exe path and type the following commands (this will open a python environment in the fmeengine context)
-If you have an error, you have a permission issue.
-If not, run the same command with the account used to run the FME Engine Service
-First use the runas command, this will open an extra window to perform your tests
I have an import error because my fmeserverservice account does not have access to c:\\temp folder.
Let me know what you found after testing this.
mmccart
  • Aug 11, 2016 6:40 PM UTC
import sys
run(config_file)
Any suggestions?
@larry I was able to load the module successfully with both my account the the domain admin account we're using to run FME Server. I am still getting the following error in the fmepreocessmonitorengine.log: Python Exception : No module named overwrite_hosted_features
I also confirmed that both accounts have full access to the C:\\TEMP\\directory in question.
steveatsafe
Forum|alt.badge.img+16
Are all environments are the same bit version? Looks like FME Server is 32bit.
mmccart
  • Aug 11, 2016 7:09 PM UTC
@SteveAtSafe It's 64-bit: FME Server 2016.1 - Build 16492 - win64
  • Aug 11, 2016 7:17 PM UTC
So it seems that there is still an issue with the service account.
If you look at the services, can you confirm that the "FME Server Engine" service is running with the expected account and not only the "FME Server Core" service?
Note that mine is a local account and not a domain one.
mmccart
  • Aug 11, 2016 7:37 PM UTC
@larry Yes, the FME Server Engines is running as the domain account that I tested with. Not a local account. The domain account is in the Administrators group on the server. Also, I explicitly gave full control to the folder in question to that domain account. Does it matter that the username running job is different than this domain account? If I go to Manage>Jobs, the Username that runs it is the user that uploaded it to FME Server originally. Is this correct? I remember from previous versions that it only showed the FME Services account.
  • Aug 12, 2016 3:47 AM UTC
I don't think the username running the job matters.
Next step is to add an EnvironmentVariableFetcher transformer to your workspace and log the value of USERNAME and USERDOMAIN when your workspace is running on FME Server to make sure we are running with the expected account.
If nothing new is found, next step is to move your python code in the FME Server resources in Engine > Transformers folder.
If you have success loading the script from there, next step will be to find a place for your
config file (maybe also in the resources under Data in a subfolder created for your project).
To access this file from your python script, you can use the FME_SHARESRESOURCE_DATA macro.
mmccart
  • Aug 16, 2016 9:39 PM UTC
-Mark
