Python import error
  • Jul 15, 2015 7:20 AM UTC
  • 5 replies
  • 55 views
Hi everyone,
I have set up a FME workspace that works fine and is scheduled to be started every day on FME server. It has a python startup script included that also works fine and has been tested.
The trouble is that the scheduled job sometimes fails, telling that the python script has produced an error :
 Python Exception <NameError>: name 'ftplib' is not defined Error executing string `# -*- coding: utf-8 -*-
The weird thing is that it happens sometimes, not every time. For now, when the process fails I just resubmit the job and it works almost everytime (it happened once that it fails again).
The ftplib is definitly included in the python environment (I tried to start <<path to fme server>>\fme.exe python and then the utf8 thing followed by import ftplib, it works flawlessly).
So I don't know where the issue can be, FME? FME Python? My script? Environment related issue?
Thank you for your help.
Anthonin
  • Jul 15, 2015 7:57 AM UTC
Hi
Is it possible that you have a workspace with a Python script somewhere that (re)defines 'ftplib'?
Try setting both these values to 1 in fmeServerConfig.txt and restarting FME Server:
MAX_TRANSACTION_RESULT_SUCCESSES=1
MAX_TRANSACTION_RESULT_FAILURES=1
This forces the engines to restart after every translation. If this works, consider analyzing all your running workspaces with Python scripts to look for potential conflicts with ftplib.
David
  • Jul 15, 2015 8:25 AM UTC
Thank you David.
I don't think I have something redfinning ftplib, but I will check.
I will try what you propose and keep this thread informed on what's going on after that (it should run at least a week before telling if it works or not).
Thanks.
Anthonin
  • Jul 20, 2015 6:47 AM UTC
So it appears not to work. Indeed the process failed the day after I made the changes. And the day after too (same error).
Besides, for some reasons I don't know why, all the processes have been queued this weekend. I back up the original configuration to see if it's better...
  • Nov 17, 2015 8:31 AM UTC
Just an update to tell that I still have the same issue in FME Server 2015. I tried to re-upload the workspace several times, use a custom Python interpreter, a try catch loop on the import... Nothing worked. It appears to only affect ftplib module. If nobody has any inputs on that, I think I will redesign my code so that it does not use ftplib anymore (I have the chance to have the data available on a classical HTTP server).
Thanks,
Anthonin
mark2atsafe
Forum|alt.badge.img+59
Thanks,
Anthonin
Have you contacted the Safe support team about this issue? If not, I think you should. www.safe.com/support
