problems reading layers from ArcGIS Server Feature service, getting Python exception
  • Feb 20, 2017 4:05 PM UTC
  • 6 replies
  • 129 views
I´m trying to extract data using an ArcGIS Server Feature service reader which is going okay. For some of the layers I´m getting the following error:
Python Exception <UnicodeDecodeError>: 'ascii' codec can't decode byte 0xe5 in position 10: ordinal not in range(128)
I´m guessing the problem relates to some characters in the tabel of the layer which can´t be read by the ArcGIS reader? Or could the problem relates to the transformer being programmed in Python 2 instead of Python 3 (which i´ve been told is handling encoding-problems better)?
I only need the geometries (and the layer names), so is there a way for me just to be able to read the those?
If that´s not possible is there a way for me to encode the tables so that I wont get the error-message?
Thanks in advance :)
Christian
Best answer by fmelizard
Hi @rkcha. The issue you encountered has been reproduced by development and problem report PR# 76052 filed. I'll let you know when it has has been addressed. I'm sorry that you encountered this problem.
  • Feb 20, 2017 4:16 PM UTC
Which version of FME is this?
Can you try using FME 2017 RC, I know there's been quite a few changes in the AGOL reader/writers in the latest versions. Download: http://www.safe.com/support/support-resources/fme-downloads/beta/
  • Feb 21, 2017 6:57 AM UTC
I´m not that experienced with the ArcGIS Server formats so I´ll excuse my lack of knowledge if that´s the problem :-).
It´s the latest FME 2017 RC that I´m using.
And it´s not the AGOL reader I´m using, it´s the "Esri ArcGIS Server Feature Service" reader I´m using.
Christian
  • Feb 21, 2017 8:19 AM UTC
Christian
Thanks for the info. Sounds like you should be contacting Safe support about this. Be sure to give them everything necessary to reproduce the error on their side.
fmelizard
Forum|alt.badge.img+22
  • Feb 21, 2017 11:25 PM UTC
  • Mar 2, 2017 12:27 PM UTC
I can see that the problem should have been solved with b17255. Unfortunately I´m still getting the same error (using 2017.0.0.0 - 20170228 - build 17259). I would like to send you the workbench and URL if that would be helpfull?
Christian
carsonlam
Forum|alt.badge.img+7
  • Mar 3, 2017 7:12 PM UTC
Christian
Hi Christian - yes, if you can provide us a URL we can access, that would be very helpful. Please submit it to our support staff.
