Problem alignment transformer
alc33
Forum|alt.badge.img+10
Hi !
I don’t know where to post that so sorry if it’s the wrong place 😊
When I use the button “alignment Middle” the alignment is vertical and when I use the button “alignment center” the alignment is horizontal. The action seems to be the opposite of the picture on the button.
Do you have the same thing? On FME 2018 is the reverse and it look more logical.
FME version : 2024.0.1.0
Thanks !
Best answer by hkingsbury
Probably best to raise this as a bug through support - https://support.safe.com/hc/en-us/p/Support
I never use the auto arrange tools, as I find it doesn’t do a great job in more ‘chaotic’ workspaces
hkingsbury
Forum|alt.badge.img+56
  • June 30, 2024
alc33
  • July 2, 2024
@hkingsbury Thanks! I will do that 😊
For me is usefull when you create the flow step by step, and you have some part with a lot of transformers and you want them to be well aligned. Effectively, use these tools directly on ‘chaotic’ workspaces is too complicated!
mark2atsafe
Forum|alt.badge.img+49
Hi! Yes, this is a known issue in 2024.0. I believe it’s fixed in 2024.1
Apologies for the inconvenience. It sure caused me to look twice when I first encountered it.
Regards
Mark
alc33
  • July 2, 2024
@mark2atsafe thanks for your answer !
yes, it was the same for me :)
