Performance Architecture: How to scale to big data?
  • Aug 28, 2013 4:24 PM UTC
  • 57 views
Oracle/FME family:
I have a gazillion tables with SDO_GEOMETRY fields in a single Oracle instance.   Most of those tables have a complex join to other tables to get interesting information to control the display.
I  have a handful of workspaces to extract this data to FFS, mainly focused on the specific geometry type, that is:   Point, Labels, Lines, Polygon.
Having just read about hadoop, map/reduce, and all that functional architecture, I got it in my head that I needed to map each geometry table to its function i.e. geometry workspace and let FME Server go wild on them.
What I decided to do is launch a workspace for each table and send in the join criteria as parameters for use in an SQLCreator.    So I end up submitting 250+ jobs, each running 1 of 6 workspaces to process a single table.  All processed by 8 engines.
Well, you can imagine what Oracle does in response to this.   It basically locks up.
My question is, what is the right way to scale?    I haven't tried a single workspace with 250+ reader/feature types, because the cutting and pasting and redundancy of the same transformers over and over, seems silly.
So I was wondereing:  what is Oracle's problem is with servicing 8 connections at a time, each servicing one table and it's related records?
I've been told that it can't hard-parse that many SQL statements at once (8!? seriously?!)  And that the queries need to use bind variables (I posted a different question about that) etc.
I've been told to use views, but that is problematic because the views would have to be created on the fly because the criteria is a subset of any given table, in my case, a wire-center, or a feeder, or a circuit.  I can't create a view for every arbitrary sub-group of data that can be requested.
Any suggestions welcome,
Thanks
Brad
Best answer by david_r
very interesting challenge. My first hunch would be to reduce the number of concurrent connections to Oracle, i.e. not running more than one engine at a time.
Also, are you sure that it is the Oracle instance that hangs or could it be the client that is clogged? Are you running 32 or 64 bit versions of FME and the Oracle client?
Regarding views, how about creating them dynamically using FME and a SQLExecutor?
David
  • Aug 29, 2013 7:25 AM UTC
David
