perform the same transformation for all attribute value outputs
  • 4 August 2017
  • 5 views
Hi, I have dataflow where I filter my data by an attribute. This results in 100+ output ports. After that I will perform the exact same transformation for every output port and write the data in a separate file. (Yes, I do need to filter first.) Of course, I can create a custom transformer for my transformation that follows (see screenshot) but I'm wondering if there's a way so I don't need to add the transformer and a writer to my workspace 100 times?
Any suggestions?
I'm using fme desktop 2016
I found a solution:
I replace the first attribute filter by using an attribute for the Counter Name (which I found serves as a group by). Like this I only have one dataflow and will use the fan out option when writing my features.
