Passing comma-separated numbers to Python function
  • August 16, 2017
  • 5 replies
  • 204 views
Forum|alt.badge.img+62
Hi everybody,
First time trying to get something done in Python so please bear with me...
I'm trying to find the greatest common divisor of a set of numbers, supplied as a comma-separated string through a User Parameter. Python has a function (gcd) that does just that (originally for 2 numbers, but through the reduce function it can iterate)
However, I can't seem to pass my numbers into the function.
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        # divisor = reduce(fractions.gcd, (10,15,25,50))
        divisor = reduce(fractions.gcd, (FME_MacroValues['Contours']))
        feature.setAttribute("divisor", divisor)
        self.pyoutput(feature)
    def close(self):
        pass
The line that's commented out works, but if I pass those same numbers through the parameter I get an error message:
Python Exception <TypeError>: not all arguments converted during string formatting
Traceback (most recent call last):
  File "<string>", line 18, in input
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/fractions.py", line 25, in gcd
    a, b = b, a%b
TypeError: not all arguments converted during string formatting
Error encountered while calling method `input'
f_11(PythonFactory): PythonFactory failed to process feature
A fatal error has occurred. Check the logfile above for details
I'm pretty sure it has something to do with how I'm passing the parameter, but I can't figure it out. Any suggestions?
  • August 16, 2017
The problem is that FME_MacroValues always returns a string, so what you're actually saying is:
divisor = reduce(fractions.gcd, ("10,15,25,50"))
Which of course won't work. Try the following to convert your string into a list of integers:
values = (int(x) for x in FME_MacroValues['Contours'].split(','))
divisor = reduce(fractions.gcd, values)
If the syntax for generating 'values' is unfamiliar to you, look up "python generator comprehension" on google for tutorials, etc.
Thanks David, that did the trick
  • August 16, 2017
The eval function could also be an option.
divisor = reduce(fractions.gcd, eval('(%s)' % FME_MacroValues['Contours']))
  • August 16, 2017
Technically I agree, but I'm not a fan of using eval() and particularly not on user specified input. See https://nedbatchelder.com/blog/201206/eval_really_is_dangerous.html
  • August 16, 2017
@david_r, you are right. Really dangerous. The eval function would not be recommended to use unless the parameter is private.
Thanks for the alert.
