Pass attribute value to FeatureReader
  • Oct 16, 2018 3:52 PM UTC
  • 286 views
sunsilk11
Hi I have used Directory and File Pathnames to get the latest file name from a directory containing a list csv files.
I then try to pass the fme attribute path_windows to a FeatureReader to read the csv file (see attached).
However this is not working. When I click on Preview, I expect to get a preview of the csv data. Also, it doesn't output the data from FeatureReader when I run it.
Any ideas
Best answer by david_r
A few things to look out for
  • If the filename is dynamic you need to configure the FeatureReader to use the <Generic> output port.
  • When using the <Generic> output port, do not specify "Feature types to read" as that will filter out any filenames that don't match that value.
  • When using the <Generic> output port, you'll have to manually expose the attributes returned by the CSV, such as "Lat", "Lon" etc.
  • The CSV parameters needs to be configured for Automatic attribute definition.
Example: processlatestcsvinlist.fmwt
  • Oct 16, 2018 4:00 PM UTC
You cannot preview the file contents since FME cannot know the value of "path_windows" until the workspace is running. And when the workspace is running you cannot preview the CSV, which leaves you in a type of Catch-22 situation.
The solution is to temporarily hardcode a CSV filename, adjust the reader settings as necessary and then point the dataset parameter to "path_windows" again just before running the workspace.
sunsilk11
  • Oct 17, 2018 10:00 AM UTC
Thanks for the response. Unfortunately this doesn't seem to work. When I replace the dataset by "path_windows", I don't get required output from FeatureReader.
See my workspace and sample csv attached.
samplefile.csv processlatestcsvinlist.fmw
  • Oct 17, 2018 10:17 AM UTC
