Oracle DB writers
  • May 16, 2018 10:06 AM UTC
  • 77 views
Hello,
I need to set specific order for writers to write because tables are connected with constraints , when one finishes second one starts and after second third starts. How can I do that? And second question, how can I commit changes to Oracle DB or FME does that after writing to DB? I am using Oracle non-spatial writer.
Best answer by nielsgerrits
Multiple possible ways:
- FeatureWriters, use multiple FeatureWriters, Holders and Testers to start the next FeatureWriter as the previous one is finished.
- SQLExecutor, create the code and order by hand and run this.
stagedfeaturewriter2018.fmw
nielsgerrits
Forum|alt.badge.img+67
  • May 16, 2018 10:40 AM UTC
fmelizard
Forum|alt.badge.img+22
  • May 16, 2018 7:02 PM UTC
Hi @luckym, check out our Let the Database Tutorial for an article on writing to Oracle when dealing with constraints.
  • May 17, 2018 8:09 AM UTC
@TiaAtSafe thank you very much, this was very helpful.
  • May 17, 2018 8:10 AM UTC
@nielsgerrits thank you, this works perfectly for me.
