ODBC Data Reader
  • Nov 29, 2012 1:13 AM UTC
  • 99 views
dos_gis
Forum|alt.badge.img+3
Hi, I'm trying to connect to a database using the ODBC 3.x data reader.  The parameters seem correct and I can see the tables in the Table list.  When I try to add the data I get the error:
ODBC2 Reader: Now reading schema for gistxtaxes Database Generated Error Information: Database Error Message: [DataDirect][ODBC Progress OpenEdge Wire Protocol driver][OPENEDGE]Table/View/Synonym not found (7519) Database SQL Statement Text: SELECT * FROM "gistxtaxes" WHERE 1=0 SQL State: 42S02 Variable Information:  ODBC2 Reader: Failed to get schema for feature type 'gistxtaxes'. Continuing with next feature type in the list
I can connect to the data base and add data in ArcMap using the same connection parameters.  Any idea what's going on?
sigtill
Forum|alt.badge.img+25
  • Dec 3, 2012 7:22 PM UTC
Perhaps you used this reader previously with another FeatureType? Try to open a new blank workspace and add a brand new reader to see if this solves the issue
dos_gis
  • Dec 3, 2012 7:46 PM UTC
Thanks.  I simply had to fully qualify the target table for it to work (pub.gistxtaxes)
