ODBC 3.x reader -- SYBASE connection ?
  • Jan 28, 2014 3:36 PM UTC
  • 35 views
kalbert
Forum|alt.badge.img+14
I have connection details to connect a Sybase DB an I try to figure out how to connect using the ODBC 3.x reader. I have no knowledge about ODBC. so my question is, what do I have to type in the Database field of the ODBC 3.x Parameter window.
I have a username and pwd, and my connection details are similar to the following
Default DB: db_prod
Server Name: MONUM99
DBMS: Sybase ASE
Any hint is appreciated
  • Jan 29, 2014 7:42 PM UTC
Check out this article (http://fmepedia.safe.com/articles/How_To/Connecting-to-Sybase-using-an-ODBC-connection-within-FME) - which shows how to get at your Sybase database. You do need to setup an ODBC connection first and then FME can make use of that.
Regards,
Robyn Rennie
FME Desktop Support
philippeb
Forum|alt.badge.img+23
  • Jan 30, 2014 8:31 PM UTC
I'll give a try for sure.
If my Sybase is on a server and FME on my desktop, where do I have to install the SQL Anywhere Database?
Thank you!
