My firewall is blocking FME Hub content when I am using FME Workbench. What can I do?
fmelizard
Forum|alt.badge.img+18
My company uses a firewall and I cannot download content from FME Hub when I am using FME Workbench!
With the help of my IT Department, I have traced this issue to a couple IP addresses that were blocked:
ec2-52-0-251-21.compute-1.amazonaws.com
ec2-54-208-208-236.compute-1.amazonaws.com
ec2-54-243-241-253.compute-1.amazonaws.com
ec2-54-165-124-56.compute-1.amazonaws.com
ec2-54-87-96-236.compute-1.amazonaws.com
ec2-54-243-173-199.compute-1.amazonaws.com
Are there any other IP addresses I should be aware of?
Best answer by rylanatsafe
FME Hub, or https://hub.safe.com, resolves to an AWS ELB (Amazon Web Services Elastic Load Balancer). This service uses multiple IP addresses. If you have strict firewall rules, you must whitelist this range.
There is a great Stack Exchange discussion on this topic and for more information about the IP range from Amazon, navigate to this page.
*Note that as a workaround, you can download content directly from FME Hub and transfer it to any machine that you cannot modify firewall rules for!
Edit: Please also view this Knowledge Center Q&A; Discussion.
Keywords: fme hub firewall troubleshooting
rylanatsafe
Forum|alt.badge.img+13
  • August 18, 2016
fmelizard
  • June 5, 2017
Please also see the comment here from GerhardAtSafe
rylanatsafe
  • September 12, 2017
Please also see: URLs Used by FME
