Missing fme attributes in SQL output ??
  • Dec 17, 2020 9:24 AM UTC
  • 104 views
lifalin2016
Forum|alt.badge.img+42
Hi all.
I'm importing some DWGs and DGNs, merging all features from all files, and adding fme_basename and fme_dataset to the input. This works fine, until output.
The output writer featuretype lists the two attributes under "Format attributes" with a green arrow. The writer featuretype dropdown also lists them. And the User Attributes are set to "Automatic".
But the writer fails to output the fme values to the database tables. Only the "autocad"/"igds" values are output.
What am I missing here ?
Shouldn't the fme attributes be included in the output ?
Need I do anything else to make this happen ?
Cheers
Best answer by lifalin2016
Happy New Year.
I guess the writers just strip any and all attributes named fme_... from the output ?
lifalin2016
  • Dec 17, 2020 10:08 AM UTC
For fun I appended "autocad_" to the fme attribute names (renamed them), and now it seems they all get output !??
What trickery is afoot here ??
lifalin2016
  • Dec 17, 2020 10:29 AM UTC
Secondary issue: How come fme_dataset defaults to char(50) ?!?
Path names are very often longer than that. On Windows they're char(127).
Using this expression luckily did the trick: (a)TrimRight((a)Value(fme_dataset)(blank)(blank))
lifalin2016
  • Jan 5, 2021 9:27 AM UTC
Happy New Year.
