merging areas by a common attribute
  • May 13, 2013 9:35 PM UTC
  • 68 views
I have several areas that have common boundaries and a common attribute.  I would like to dissolve the lines that touch to make one larger area.  I tried the amalgamator, but that didn't work, I have also tried the aggregator, but that isn't working either.  The data is an access workspace for a geomedia layer.  Any suggestions would be helpful.
Thank you.
  • May 14, 2013 12:41 AM UTC
Hi Joan,
Did you try Dissolver transformer?
Takashi
  • May 14, 2013 7:00 AM UTC
Hi Joan,
Takashi is spot on, the Dissolver will do the trick. Specify the common attribute in the Group By to only dissolve those with a common value.
If the areas aren't perfectly aligned, consider inserting a Snapper (or similar) before the Dissolver.
David
I tried the Dissolver, but my data is in an access table from Geomedia, should I export it as a shape file or something else so the dissolver will recognize it as geometry?
Thank you.
  • May 15, 2013 1:26 AM UTC
Which reader are you trying to read the geomedia data with? I think you can read geometries normally with the FM0 (Intergraph GeoMedia Access Warehouse) Reader...
Takashi
