Mapping attribute value on the fly
  • Aug 27, 2015 11:59 AM UTC
  • 81 views
I have 15-20 feature types that have values of the same type and they can be repetitive (e.g. FeatureType1: 1, 2, 3, 5, 4; FeatureType2: 1, 6, 8, 3, 5 and so on). These features are tables from SQL Server with relationships (because of that there are repeating values). I need to change all values of certain (different) attributes in all features to some other set (number sequence that starts from specific number). So, all primary and foreign keys from ex tables need to be mapped to some range. Confusing, I know, but I will try with example too.
Some example of data:
Parcel1: oid=224
Parcel2: oid=266
Parcel3: oid=214
Building1: oid=844, parcel=224
Building2: oid=415, parcel=266
Building3: oid=332, parcel=214
Building4: oid=711, parcel=214
Here I need to get parcel oids (e.g.) 21-23, building oids 24-27 and building parcels 21-23, respective to original attributes. New values could start from any number (set as parameter) and there must not be any skippings. It doesn't need to be ordered, but must be continuous. All features have oid and some of them has foreign keys to oids of another feature/
What is the simpliest way for doing this, no matter how much complicated it is?
AttributeValueMapper uses static mapping, but I need to use dynamic. Maybe I can extract all interesting fields to some file from SQL Server, but I'm not sure.
Any suggestions for solving this problem will be appreciated.
Greetings,
Aleksandar
  • Aug 27, 2015 3:24 PM UTC
If I understood the requirement correctly, this workflow would do the trick.
Takashi
  • Aug 27, 2015 4:06 PM UTC
Hi Takashi,
Thanks for quick answer. This is what I need, almost. Thing is that I have more than 10-20 different feature types that are related on 'many' attributes. I know to make mapping for e.g. these two feature types, but what about the others? If I implement this logic on all of the feature types, it will make a hell of my workspace. So, yes, you have understood the requirement correctly, but what about other feature types?
Aleksandar
P.S. Thanks a lot for the workflow!
