Make a loop without limit
  • Aug 6, 2018 1:13 PM UTC
  • 5 replies
  • 72 views
geo-x
Dear FME community.
I would like to make a loop with concatenation of values like a hierarchy.
The result like that :
In this case I can have 1, 2, 3, ... x levels, that's why I don't know how to do that.
Thank you for your help.
Best answer by david_r
You could use the VariableSetter and VariableRetriever for this, see attached template (FME 2018.1).
Result:
build-hierarchy.fmwt
  • Aug 6, 2018 1:37 PM UTC
Hi @lalandexavier, it's an interesting challenge. This is my first inspiration.
# Possibly the RESULT for ID = 6 should be "B/F"?
  • Aug 6, 2018 1:39 PM UTC
Result:
  • Aug 6, 2018 1:40 PM UTC
Almost exactly the same :-)
geo-x
  • Aug 6, 2018 4:05 PM UTC
Result:
Thank you very much @david_r that's perfect !
geo-x
  • Aug 6, 2018 4:07 PM UTC
Thank you very much @takashi Your answer complete the answer of @david_r
