LOG file location in shutdown script
  • Aug 13, 2014 3:28 PM UTC
  • 84 views
    My workbench is published in FMEServer. At the end of workbench execution, i have to log the generated LOG file and FFS file complete path in database . I thought of doing it in shutdown script. But i do not know how to get their location.
Any pointers will be highly helpful.
Thanks.
Subrat
  • Aug 13, 2014 4:07 PM UTC
starting with FME 2014, you can get the FME log file location in a shutdown script like this:
import fme
log_file_name = fme.logFileName
For your FFS file, it is not so simple, but I guess that you can publish the FFS filename as a parameter and then access it the usual way through the FME_MacroValues dictionary, e.g.
ffs_file_name = FME_MacroValues['MY_FFS_FILENAME_PARAMETER']
David
  • Aug 13, 2014 5:19 PM UTC
Thanks David for the solution. Unfortunately, my project has licenced FME Server and Desktop 2013.
I tried in FME desktop 2013 SP4 (20131025 - Build 13547 - WIN32) and i am getting following python error.
Python Exception <ImportError>: No module named fme
Error executing string `import fme
print 'log_file_name:',log_file_name'
FME_END_PYTHON failed to execute provided script
FME_END_PYTHON failure
Program Terminating
Is there any way to solve the problem in this FME version?
Thanks.
  • Aug 14, 2014 6:53 AM UTC
Hi Subrat,
try using pre-defined variable "FME_LogFileName" instead.
Takashi
