Load WMS with BBOX into my workbench
  • Oct 24, 2016 2:33 PM UTC
  • 125 views
Hi!
I want to load a Web Map Service into my workbench with the FeatureReader. It works almost perfectly, but I want to use a bbox as a geographic filter for my WMS. The problem is that you can't insert a bbox in the WMS parameters of the reader. Is there a possibility to specify a bounding box?
Best Regards,
Felix
  • Oct 24, 2016 3:00 PM UTC
Your initiating feature should include the bounding box geometry (e.g. using the 2DBoxReplacer or the BoundingBoxReplacer), and in the FeatureReader you should set the spatial filter to "Envelope intersects".
itay
Forum|alt.badge.img+19
  • Oct 24, 2016 3:31 PM UTC
Hi @felixdergluecklTrue, as @david_r mentions your initiating feature geometry can be used as a bbox for the request in the FeatureReader.
If you are dealing with non spatial initiators, you can build the service request and incorporate a bbox into it.
  • Oct 24, 2016 3:43 PM UTC
It's extremely easy to use the 2DBoxReplacer to turn your non-spatial initiator into a spatial initiator, however.
