List parameter
  • Aug 16, 2013 7:29 PM UTC
  • 29 views
Hi, I have a model that contains a files that has information about multiple projects. I would like to pass a parameter to allow the user to select on or multiple projects from a list. Any thoughts? guidance? advice?
Thank you
  • Aug 17, 2013 2:28 AM UTC
Hi Gerardo,
How about creating a published parameter whose type is "Choice (Multiple)" ?
You can import  parameter values (i.e. choices) from a file when defining the parameter.
Takashi
  • Aug 19, 2013 2:23 PM UTC
Takashi, thanks for your response!!
I had tried that,  but when  I ran the model, nothing happened, all projects ran. I
added a parameter fetcher and it didnt work either. Am I missing something?
Thanks
  • Aug 20, 2013 5:23 AM UTC
Hi Gerardo,
I suppose you need to run the projects (workspaces) whose file names were selected as the published parameter (choices).
If my understanding is right, this workflow might be a solution.
(image)
Assume the parameter (WORKSPACE_NAME) value is white-space-separated workspace names (full paths).
Takashi
