List in httpfetcher url
  • Aug 7, 2015 1:15 PM UTC
  • 72 views
I'm setting up a workflow to download data from the police.uk API and eventually I want to set it up to run every few months or so to get updated data.
I'm using the street-crimes method to feed in a lng/lat string and get all crimes inside the polygon the coords generate. https://data.police.uk/docs/method/crime-street/
This initial bit is working well so far.
The method outputs a single months data and what I want to do is get the httpfetcher transformer to send multiple requests to get several months worth of data.  I don't mind it rerunning this each time as the police may update older crimes so getting updates would be fine.
My thought was that I could build a list with each month I want to request data for and feed that into the target url httpfetcher.  I don't really know if that would work and I haven't really worked with lists yet so I'm not really sure how to create one.
Any thoughts on this approach and any tips on creating the list of months initially?
  • Aug 7, 2015 2:18 PM UTC
Hi
By looking at the API it seems that it wants a parameter like 2015-08 to specify the month. One way to solve it using FME is to create a feature (e.g. Creator or Cloner) for each month and then do a separate call. It is possible to calculate incrementing month and year numbers using e.g. the ModuloCounter, but is is (IMNSHO) a bit long-winded.
Here is a PythonCaller script that will return an incrementing series of Year-Month values for each feature that passes through it:
import fme
import fmeobjects
class IncrementMonthYear(object):
    def __init__(self):
        self.month = int(FME_MacroValues['START_MONTH'])
        self.year = int(FME_MacroValues['START_YEAR'])
        self.count = 0
    def input(self,feature):
        if self.count > 0:
            self.month += 1
        if self.month > 12:
            self.year += 1
            self.month = 1
        self.count += 1
        feature.setAttribute('year_month', '%04d-%02d' % (self.year, self.month))
        self.pyoutput(feature)
--- It assumes you have defined two published parameters START_YEAR and START_MONTH that says when to start.
You can then expose the attribute "year_month" and use it in your HttpCaller parameter.
David
  • Aug 7, 2015 3:19 PM UTC
Thanks, I'll have a look at that, not done anything with Python before so will see if I can work it out!
