Lines within polygon selection using NeighborFinder
  • Jun 13, 2024 8:32 PM UTC
  • 175 views
fme_can_do_it
Forum|alt.badge.img+13
I need to select the lines that fall entirely within a specific polygon and update their data with the respective polygon name. I attempted to use a spatial filter, but it didn't work as expected. When a line intersects two polygons, the filter selects and attributes the line to only one of the polygons, which is causing issues. I also tried using the NeighborFinder without success. I've attached a screenshot to illustrate a line segment that should not be selected within this polygon.
Best answer by DanAtSafe
Hi @fme_can_do_it Did you test with the spatial predicate "Filter OGC-Contains Candidate"?
DanAtSafe
Forum|alt.badge.img+23
  • Jun 13, 2024 9:07 PM UTC
andrewj74
Forum|alt.badge.img+8
  • Jun 14, 2024 9:36 AM UTC
liamfez
Forum|alt.badge.img+44
  • Jun 14, 2024 2:01 PM UTC
I agree with @DanAtSafe and @andrewj74, you should check what test is being used.
If you were interested in the case that you mentioned, where a feature intersected 2 polygons, then I would recommend the SpatialRelator, it will give you a count of related features, and you can generate lists for those related features.
fme_can_do_it
  • Jun 14, 2024 5:49 PM UTC
Thank you all for your help! The issue has been fixed.
