JSON Templater - All rows in one output
  • Sep 2, 2024 1:18 PM UTC
  • 101 views
sam_appleton
Forum|alt.badge.img+7
Hi All,
I have a json templater which i’m using to create a json that has ‘firstname’ and ‘lastname’ - there’s 3 rows of data.
I created the following in the root template but it outputs the 3 separately:
       "firstName" : fme:get-attribute("first_name"),
       "lastName" : fme:get-attribute("last_name")
I then tried creating a sub template -with the following settings:
Here is the output I get:
{ "firstName" : "first2", "lastName" : "Last1" }{ "firstName" : "first2", "lastName" : "Last2" }{ "firstName" : "first3", "lastName" : "Last3" }
I can see that it’s missing an extra set of curly brackets, and when trying to run this result through a JSON validator it fails and gives this message:  “Unexpected non-whitespace characters were found after the JSON text”
I’ve looked at the JSON templater documentation and the exercise but I can’t seem to get this working.
Any help would be greatly appreciated
Many thanks,
Sam
itsmatt
Forum|alt.badge.img+48
  • Sep 9, 2024 7:51 AM UTC
This doesn’t answer your question directly, however, in this case I would use an AttributeCreator with an Aggregator to just build the document.
JSONTemplator has a habit of complicated things.
What you are creating here though is more of a list of objects which is a little funny. Typically these would instead all be in an array. Although of course the don’t have to be.
  “names” :[
        “firstName” : “Alice”,
        “lastName”: “Bloggs”
        “firstName” : “Bob”,
        “lastName” : “Bloggs
This is more the kind of thing the json template expects to produce.
