Is there a way to decode a field to export the KMZ, that is stored in Base64
  • Apr 14, 2021 7:47 PM UTC
  • 86 views
Hello, I have a field in a database where KML's are uploaded and stored in Base64. Is there a way to export those and convert them to KML within FME? My end goal was to convert to KML, then covert them to shapefile for a Portal Layer. For example attached is one of the files encoded that I confirmed is a KML by manually decoding it outside of FME. I tried the BinaryDecoder transformer, but I wasn't sure what to do with the result.2021-04-14 15_47_02-Google Earth Pro
hkingsbury
Forum|alt.badge.img+73
  • Apr 14, 2021 8:19 PM UTC
A BinaryDecoder into a AttributeFileWriter will do the trick :)
See attached Workbench
