Insert and Delete rows in a MapInfo table
nicholas
Forum|alt.badge.img+14
I have a MapInfo table which I want to modify by inserting and/or deleting records.
I would like to modify the MapInfo table in place.
I think that I can use the Precisely MapInfo Extended TAB Writer Feature Type Parameters?
https://docs.safe.com/fme/2022.1/html/FME_Desktop_Documentation/FME_ReadersWriters/mapinfo_extended/mapinfo_extended-ft-param-w.htm
My software is FME Desktop FME(R) 2022.1.3.0 (20220928 - Build 22630 - WIN64)
But how do I build a workspace that performs this task?
How do I build a Writer transformer that recognises an existing MapInfo table?
j.botterill
Forum|alt.badge.img+40
  • May 27, 2025
Hi Nicholas,
You will want to build a Change Detection workspace. Safe software recently held a two part webinar on this topic.
 https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/changedetector.htm You want the existing TAB going into Original port and the new data into the Revied input port. Coming out of the transformer are Insert, Update, Delete ports and a format attribute called fme_db_operation which you use in the writer table operations instead of simply Insert or Update.
nicholas
  • May 28, 2025
I figured it out
The trick is to use the Precisely MapInfo Extended TAB Writer and take advantage of the Feature Operation
To Insert new rows
Reader
This is a simple MapInfo (MITAB) Reader. It's job is to Read the new rows that are to be inserted
Writer
This is a Precisely MapInfo Extended TAB Writer
The Table Name is the name of the "master" table
The Feature Operation is Insert
Note that the Feature Operation uses the Existing table
This will Insert the Input features
The table is saved at the end.
To Delete existing Rows
Reader
This is a simple MapInfo (MITAB) Reader. It's job is to Read the rows that are to be deleted. There must be a column with an identifying unique value.
Writer
The table name is the name of the "master" table
The Feature Operation is Delete
Note that the feature operation uses the Existing table and also performs a Pack
The Row Selection is by Matching a Column
In this case, any row with a value in the districtcode column that matches the Input features will be deleted.
(I did have a bunch of screenshots, but they make my post too large for the forum)
