In the FME ,we have included python startup script. When we run it in FME 2014 version, it showing an error like : name 'dbCursor' is not defined.Could you please temme what would be the reason?
Best answer by takashi
The variable "dbCursor" is defined inside of the "try" block, so it cannot be accessed from the "except" block. Try inserting these lines before the try block.
dbCursor = None
dbConnection = None
Indentations are important in Python scripts. Please use the CODE block when posting a script in the next time.
pratap
Forum|alt.badge.img+11
  • December 21, 2015
I don't know python but when I tried for first-time even I too received the error.
In Python, position of starting of line and ending of line is most important. So re-write the script in editor in the position where it starts and end.
Hope this helps :)
Pratap
Forum|alt.badge.img+19
  • December 21, 2015
The error occurs if a variable called "dbCursor" is not defined before using it in the script. Cannot think of other things unless seeing the actual script.
@takashi Here is the actual script
import fmeobjects
import cx_Oracle
import sys
#Getting the database paramters
service = FME_MacroValues['DBService']
userName = FME_MacroValues['DBUserName']
password = FME_MacroValues['DBPassword']
updateImportIDProc= 'NBN_DATA_OWNER.UPDATE_NBN_DATA_LOG'
getImportIDProc = 'NBN_DATA_OWNER.GET_NBN_IMPORT_ID'
#Getting the current process Id
importID =-1
#Creating connecting strings
connectionString = userName + '/' + password + '@' + service
try:
dbConnection = cx_Oracle.connect(connectionString)
dbCursor = dbConnection.cursor()
dbCursor.callproc(updateImportIDProc,('UPLOADING','NBN_FPRNT'))
#checking the run status of 01_CleanUp_Input.fmw workspace
id = dbCursor.var(cx_Oracle.NUMBER)
dbCursor.callproc(getImportIDProc,('NBN_FPRNT',id))
#raise Exception("Translation failed, 01_CleanUp_Input.fmw is not yet finished")
importID = id.getvalue()
if importID==-1:
raise Exception(message)
if dbCursor is not None:
dbCursor.close()
dbCursor=None
if dbConnection is not None:
dbConnection.commit()
dbConnection.close()
dbConnection=None
except Exception, e:
print str(e)
importID = -1;
dbCursor.close()
dbCursor=None
dbConnection=None
sys.exit()
  • December 21, 2015
dbCursor = None
dbConnection = None
Thnq @takashi ...it got resolved. And now iam getting an error saying like
Unable to configure the XML module to read the XML dataset. No <xrs:switch> item in the xrs document 'D:\\apps\\FME\\xml\\xrs\\xrs.xml' matched the XML dataset 'D:\\IDW\\Data\\XML\\Historical Footprint List C.xml'
The XML format could not be determined by examination. Try entering a feature path into the "Elements to Match" parameter, specifying an xfMap, selecting an XRS, or using a more specific reader
The XML Module halted on error, see the logfile for details
Could you please help me in dis?
  • December 21, 2015
Looks like the error is from an XML reader in your workspace. Isn't it?
If so, please post it as a new question (with more detailed explanation about the reader setting so that we can understand the situation).
yeah @takashi sorry...now everything is fine thnqqq
