Identify maximum value by group and tag feature
  • Aug 22, 2018 1:20 PM UTC
  • 326 views
aron
Forum|alt.badge.img+16
I have a set of grouped features and want to identify the feature with the highest value in one of the columns, lets call it "MAX_attribute", for each group. I can find the highest value in each group by using the StatisticCalculator. But that only gives me the "MAX_attribute" for the group as an whole, I also need to identify and "tag" the actual feature that had the "MAX_attribute".
To give you an example: I have depth readings for a number of lakes, and now I want to find the deapest reading for each lake.
I also tried the Aggregator with the ListRangeExtractor but could not make it work as I wished.
Best answer by ebygomm
If this is from your earlier scenario, you can create a list in the dissolver. Sorting this list in descending order will mean you can access the feature with the highest attribute
  • Aug 22, 2018 1:27 PM UTC
Hi @aron, I think the features output from the Complete port of the StatisticsCalculater have you desired attributes.
Forum|alt.badge.img+54
  • Aug 22, 2018 1:59 PM UTC
aron
  • Aug 24, 2018 10:11 AM UTC
Thanks! I got this to work for me!
