HTTP Post via webhook (Data Streaming and Job Submitter) creates Java AccesDenied error on FME Server 2020.1
  • Jul 14, 2020 12:08 PM UTC
  • 189 views
jtermaaten
Last week we upgraded FME Server to 2020.1. Since then our Data Streaming and Job Submitter Services as applied via webhooks don't work anymore. The log files indicate some AccessDenied-problems.
  • localhost_access_log: Post call received
  • datastreaming and jobsubmitterservice logs: request received. Fatal error: Service failed: java.nio.file.AccessDeniedException: E:\\FMEServerData\\resources\\system\\temp\\requestdata\\1710266074152417324
FME Server runs on a service account with admin rights to all of the server.
How to solve this?
jtermaaten
  • Jul 16, 2020 10:58 AM UTC
We found a solution for this problem in the workbenches itself. The Reader that is used to send the HTTP Message Body to should have a source. The source cannot be left empty.
I thought in previous versions of FME Server this didn't result in an error, but it does now in version 2020.1. Can this be considered a bug?
steveatsafe
Forum|alt.badge.img+16
Hi @jtermaaten,
I would have expected this to also return an error in earlier versions of FME Server. If you still have a log file (and a workspace) for the older version that would be great to help us compare to 2020.1 behaviour.
Either way, I think the Reader is attempting to read from the temp location - possibly assuming a file was uploaded so when it tries to access the temp folder, there is no file there and errors.
Would you be able to submit a case for this so we can determine if this is indeed a bug?
Could you include more details on the workflow, a workspace, and the log files mentioned in your initial post?
Thank you!
warrendev
Forum|alt.badge.img+28
  • Jul 27, 2020 6:55 PM UTC
I'm glad I found this post! I could not figure out why I was getting the error 500 code when I had all the permissions setup correctly. I just had to put in a placeholder for the reader parameter and republish to FME Server, then everything worked perfectly. Thanks for the workaround @jtermaaten!
Hopefully this gets fixed going forward, as this isn't the same behavior as previous versions of FME Server.
Case #: C159192
I had a similar error after upgrading with a datadownload service. My only reader was a Geodatabase reader, and I never sent content to the reader. But in the publish settings, I had set this reader as a reader where the body should be sent to:
wrong configuration:
fme_wrongThis was not an issue in earlier versions. my fix:
fme_correct
