HTMLReportGenerator - Interactive Map
deanhowell
Forum|alt.badge.img+23
I would like to try and create a map series using HTMLReportGenerator that will contain a map and a table where the user can select a feature in the table and the map zooms to the selected feature (or a new map is displayed) with the relevant information.
Is this possible?
Forum|alt.badge.img+50
Not with the standard map widget in the HTMLReportGenerator, you'd have to use the Custom HTML option and work with a mapping API (like Leaflet or Google Maps) to achieve this.
deanhowell
  • April 11, 2022
Thanks @Hans van der Maarel​ the custom html option certainly seems the way to go.​
