how to write a FME data to oracle database ?
I'm trying to store the sysdate to an oracle database table; i have already acquired the system date by
Timestamper
with format "FME Date/Time (^Y^m^d^H^M^S)" and setting my attribute. I get an error when the process is trying to wrtite this attribute to the oracle table. Do I need to use some transformer or oracle string conversion function ? (like to_date('@mysysdate', 'YYYYMMDD')
thanks in advance
erik_jan
Forum|alt.badge.img+19
  • April 11, 2016
Usually (depending on the settings for your database) Oracle requires dates to be written using the format DD-MON-YYYY, in the DateFormatter %d-%b-%Y.
gio
Forum|alt.badge.img+15
  • April 11, 2016
NLS_DATE_FORMAT
You need to conform to this setting if you write(to) attributes with dateformat.
You can query the attribute to find out wich format is used.
SELECT * FROM V$NLS_PARAMETERS
(for all of em)
erik_jan
  • April 11, 2016
Or if you do not have the rights to access the data dictionary view mentioned by @gio yu can select the system date by using 'Select sysdate from dual;' and view the required formatting.
  • April 11, 2016
If your attribute value looks like 20160411104915 and your date column is defined as a DATE, you have nothing to do and FME should take care of doing the proper call to Oracle (if you are using a feature writer).
If you are using SQLExecutor, you have to use the TO_DATE function like in the following query when your date attribute is mysysdate:
INSERT INTO MY_TABLE (DATE_COLUMN)
VALUES (TO_DATE(@Value(mysysdate), 'YYYYMMDDHH24MISS'))
What is the error message you are receiving and what is the value of the attribute if you log the feature just before writing it to Oracle?
  • April 11, 2016
Agreed, this perfectly reflects my experience. I've never had to take NLS_DATE_FORMAT into account using this strategy.
