How to use Schema from generic FeatureReader in generic FeatureWriter while setting destination with Published Parameters?
  • Feb 3, 2021 1:30 PM UTC
  • 0 replies
  • 278 views
erikboehm
Forum|alt.badge.img+3
retrive_schema_from_genericI use FME 2020.1.3.
What I want to do is to use a FeatureReader to read a PostGIS DB depending on created attributes ( usual generic approach) and to write them to an other PostGIS DB with an FeatureWriter, using Published Parameters to define the destination. As I use the generic port as outpur from the FeatureReader, the data loses its data-type information. I know, that those informations are given through the Schema port of the FeatureReader and that there is a way to merge them again to the data.
I found serveral post about this topic (
https://community.safe.com/s/question/0D54Q000080hbiSSAQ/generic-attribute-from-featurereader
https://community.safe.com/s/question/0D54Q000080herD/featurewriter-cannot-configure-dynamic-schema-based-on-schema-feature-when-fanning-out-destination-dataset
https://community.safe.com/s/question/0D54Q000080hfvxSAA/writing-table-with-featurereader-featurewriter-produces-inconsistent-results-in-fme-2018
Unfortunatly, I don't understand how to do it in my case.
The pictures shows, what I have done so far.
Additionally, I expose the attribute read by the FeatureReader inside it, I dont know if that's right. What do I need to expose where and when?
Thank you in advance for any guidance in this topic!
