How to use PythonEmailer with office 365
  • February 10, 2016
  • 5 replies
  • 71 views
erik_jan
Forum|alt.badge.img+18
I am trying to send an email using the PythonEmailer.
This works fine if I use the smtp.gmail.com server.
But I can not get it to work with the smtp.office365.com server TLS and port 587).
Has anybody got that working.
Any help is appreciated.
This is the error message I am getting:
Python Exception <SMTPException>: SMTP AUTH extension not supported by server.
Error encountered while calling function `email'
f_8(PythonFactory): PythonFactory failed to process feature
Best answer by brianatsafe
Hi @erik_jan,
Can you try switching from TLS to SSL in the transformer parameters? See if that works for you.
Their documentation here: https://support.office.com/en-us/article/Outlook-s...
suggests that some clients refer to implicit TLS as SSL.
brianatsafe
Forum|alt.badge.img+11
  • February 11, 2016
Hi @erik_jan,
erik_jan
  • February 11, 2016
brianatsafe wrote:
Hi @erik_jan,
Hi Brian,
I have tried all combinations available:
TLS and SSL,
SMTP, POP and IMAP
ports for SMTP (587), IMAP (993) and POP (995)
But no combination worked.
brianatsafe
  • February 11, 2016
erik_jan wrote:
Hi Brian,
TLS and SSL,
SMTP, POP and IMAP
Hi @erik_jan ,
Perhaps the python code within the transformer could be improved.  Can you try to add the following to the PythonCaller code within the custom transformer:
smtp.ehlo()
smtp.starttls()
smtp.ehlo()
Place it here:
 # Determine how we want to begin the connection
    if (connection_type=='TLS'):
        smtp=smtplib.SMTP(server,port)
        smtp.ehlo()
        smtp.starttls()
        smtp.ehlo()
    else:
Found from: http://stackoverflow.com/questions/64505/sending-mail-from-python-using-smtp
erik_jan
  • February 11, 2016
brianatsafe wrote:
Hi @erik_jan ,
smtp.ehlo()
smtp.starttls()
smtp.ehlo()
Place it here:
        smtp.ehlo()
        smtp.starttls()
        smtp.ehlo()
    else:
Thanks @BrianAtSafe
That works fine.
Will this be implemented in the FME Store version of the PythonEmailer?
brianatsafe
  • February 11, 2016
brianatsafe wrote:
Hi @erik_jan,
Absolutely, I will make sure we look at implementing this enhancement. I'm glad it worked for you!
