How to set log file as a parameter?
mzebrows
Forum|alt.badge.img+3
I need to set log file path as a parameter. So I ‘ve added User parameter LogFile and linked it to log file in
Navigator-Workspace Parameters-Logging
I’m running my workflow as follows:
"C:\Program Files\FME2\fme.exe" C:\FME\mz\WybranaSiecPomDgn2k.fmw --LogFile "c:\Folder1\File.log"
The problem is, that “c:\Folder1” folder does not exists, and the following error appears:
“Unable to open log file `c:\Folder\File.log'. The preceding error has occurred during FME logfile setup
Program Terminating”
I was trying to create “c:\Folder1” folder using Scripting-Startup Python Script, but it doesn’t help, probably because FME tries to create log file before Python script execution.
hkingsbury
Forum|alt.badge.img+50
  • January 26, 2025
There is an open improvement suggestion for this
Didn’t realise it was 8 years old! Surely this can’t be that hard to implement…..
@siennaatsafe can we grease the wheels on this? 😅
siennaatsafe
Forum|alt.badge.img+10
Hi ​@hkingsbury,
I’ve raised this suggestion with our product management team, and I can confirm that it’s on their radar. While it’s not currently scheduled for development in the next three months, it remains under consideration as we plan future updates.
hkingsbury
  • January 27, 2025
siennaatsafe wrote:
Hi ​@hkingsbury,
Thank you!! 🤗
mzebrows
  • January 28, 2025
Is there any workaround for this issue? I mean, how to tell FME, where log file should be stored?
Forum|alt.badge.img+46
As long as the folder where the logs should be written to exists you can simply specify it in the Navigator as shown in the top post. If I understand it correctly, their problem was that that folder didn’t exist yet when FME tried to create the logfile.
