How to run the same workspace many times with different parameters?
  • Jun 4, 2018 2:43 PM UTC
  • 72 views
It is similar to https://knowledge.safe.com/questions/30005/how-to-run-same-workspace-multiple-times-with-diff.html, but not exactly.
I would like to run the same workspace a number of times using different GDB as input and producing different outputs. For example, GDB1 as input produces 1.dwg as output. GDB2 - 2.dwg.
Thank a lot in advance! @ blueinc
erik_jan
Forum|alt.badge.img+26
  • Jun 4, 2018 4:06 PM UTC
I would create a CSV file (or similar) with input and output names.
Then Create a workspace that reads the CSV file and passes the values to a WorkSpaceRunner transformer that runs the main workspace per record in the CSV file.
