How to reference CSV from Writer for S3Connector?
  • Mar 23, 2022 3:29 PM UTC
  • 84 views
How can I reference the CSV created from a Writer to upload to AWS S3 using S3Connector? I can successfully use a Reader to reference a file on my computer and upload to AWS S3 using my Web Connection and S3Connector, but I don't know how to reference a newly created file within my worflow. See attached.
Best answer by chrisatsafe
Hi @osdev​ ,
You'll likely want to use a FeatureWriter instead. The FeatureWriter is essentially the transformer version of a writer which allows you to continue processing after a file has been created. If you replace your CSV writer with a FeatureWriter, you can simply connect the summary port to the S3Connector and use the summary attribute _dataset to set the file to upload (i.e. @Value(_dataset)\\<filename>.csv).
imageIf you want to only create a temporary csv you can also mix in a TempPathnameCreator.
chrisatsafe
  • Mar 23, 2022 3:52 PM UTC
Hi @osdev​ ,
  • Mar 23, 2022 7:02 PM UTC
The FeatureWriter transformer worked great! Thank you.
