How to group multi line (text file) into individual features?
  • Mar 4, 2016 9:43 PM UTC
  • 10 replies
  • 292 views
I received a text file that has descriptions about features as follows:
ADD FUSE 9911 {
PHASES =1;
PORT_A = <123>;
PORT_B = <234>;
ATTRIBUTE[county] = "SEATTLE";
ATTRIBUTE[street] = "MAIN ST";
ATTRIBUTE[facility_id] = "1324";
ATTRIBUTE[feeder_id_1] = "FD1";
ATTRIBUTE[feeder_id_2] = "Null"; }
ADD 1p_conductor 125623 {
Now, how to create individual features out of these?
1. I tried Aggregator:
groupby - text_line_data
Separator character: };
2. Tried to loop text_line_data and break whenever "};" is encountered. But both didn't work.
Is there a simple way to do this?
Best answer by erik_jan
Read the text file into one attribute.
Use the AttributeSplitter and split on }; to create a list.
Use the ListExploder to generate objects per list item.
That will generate the different features.
Next you want to split each feature again on ; to get the different attributes in a list.
erik_jan
Forum|alt.badge.img+26
  • Mar 4, 2016 9:50 PM UTC
gio
Forum|alt.badge.img+15
  • Mar 7, 2016 3:55 PM UTC
@vindastra
That will ignore the first itemname..
Use a txtreader read by row.
Ue a variableretriever and searchers
The not matched will give (in order). the attributes and value rows.
Test for not empty rows and rows witt "neither ";" nor "}" (newlines/carriagereturns etc.) and then searchers again.
Then..well.. here is example..
mark2atsafe
Forum|alt.badge.img+59
geospatiallover
Participant
What's the best transformation to make a value pair (attribute name=attribute value) stored in a list element _attribute(1) into a feature attribute name and attribute value. e.g. see screenshot. So a feature with _attribute(3) with value "iso=0" will have a new attribute named "iso" and a value of "0". 2016-03-31-07-21-57-fme-data-inspector.png
geospatiallover
Participant
I tried the KeyValueAttributeCreator but it seems by Key,Value pair delimiter which is a LF or \\n is not being read.
  • Mar 31, 2016 2:41 PM UTC
Hi @geospatiallover, I think a quick way is to remove "<any string>=" from the values, then rename the list elements. e.g.
geospatiallover
Participant
@takashi....thanks. I started with a renamer after my splitter and got lost with putting an expression on the output value. Thanks for your help once again. Strings have always been my weakness in FME.
geospatiallover
Participant
Just a thought, what if the attribute name keeps changing? This is metadata for UAV collected JPEGs and once another camera is used then the attribute schema will change. Any suggestions @takashi? I sure hope Safe would have a JPEGExif writer soon. Not a lot of voters yet on this idea.
  • Mar 31, 2016 10:14 PM UTC
You can use the KeyValueAttributeCreator after you have concatenated the list elements with a specific delimiter string. e.g. using the ListConcatenator.
geospatiallover
Participant
Thanks again!
