How to extract the coordinates (x,y,z) of all vertices of a polygon and add it as attribut
  • Jun 21, 2018 2:35 PM UTC
  • 853 views
I am new in using FME and it seems that there are something that I am missing, I found the
"CoordinateConcatenator" transformer that I think can do what I need. I open my shape file as a reader ,I choose the CoordinateConcatenator transformer and then I choose a new shapefile file as writer (output).
It runs with no error but no new attributes containng the coordinated of the vertices in the output file.
I tried to add attribuet creator, attribute writer ,nothing works ,what am I missing?
Thanks for your help!
jdh
Forum|alt.badge.img+41
  • Jun 21, 2018 2:38 PM UTC
Is the attribute containing the coordinates listed on the shapefile writer feature type? If your user attribute definition is not set to automatic, you'll have to add it manually.
  • Jun 21, 2018 3:14 PM UTC
  • Jun 21, 2018 3:16 PM UTC
the-coordinat is the name of the field that i creat with coordinateConcatenatot transformer
  • Jun 21, 2018 3:30 PM UTC
actually ,it worked when the geometry was lines . When I use polygons ,the shape file name changes to "fme_feature_type" and no output
