How to aggregate without losing attributes?
  • November 19, 2018
  • 160 views
Hi there!
I am trying to aggregate features here on picture.
Aggregation is necessary because I have to translate. scale and rotate these objects together as one object so they can fit inside certain rectangular (defined by ID).
Thing is, every circle has different set off attributes and when i Aggregate them and later Deaggregate them I lose unique attributes and get only one attribute set that was set by Aggregator for all circles.
Best answer by ebygomm
When aggregating make sure you generate the list which will hold all the original attributes. When deaggregating ensure that you select the Accumulation Mode only use list attribute values (assuming you don't need to keep any attributes created whilst aggregated)
Forum|alt.badge.img+39
  • November 19, 2018
Thank you very much. I missed List generation when aggregating. Helped me a lot!
