How do I use a parameter to call a feature class in a Feature Reader when I run a workbench from a python script?
  • Feb 7, 2019 2:47 PM UTC
  • 143 views
surbhi
I am trying to read metadata in FGDC format from a feature class using a python script and workspace runner to call in a workbench. I want to know how I can set a parameter to call a feature class from a geodatabase.
Best answer by markatsafe
You should be able to use the reader parameter called Feature Types to Read. It's available on all readers and in the FeatureReader
  • Feb 8, 2019 7:54 PM UTC
surbhi
  • Feb 8, 2019 8:05 PM UTC
thanks @MarkAtSafe !
that worked for me when I read a feature class from a file geodatabase.
However when I try to do read a feature class from a SDE geodatabase, I get an error which starts with 'Too many recursive macro substitions -- line currently is: `SOURCE_READER GEODATABASE_SDE CONNECTION_FILE "$(CONNECTION_FILE)"
Do you know what may be causing this error?
@surbhi It looks like you've created a parameter and are using that parameter to set the SDE connection file parameter that already exists. I might try disabling your existing Geodb SDE reader in the navigator and then adding a new Geodb SDE reader from scratch and see if that fixes your workspace
germang
Forum|alt.badge.img+16
  • Mar 24, 2022 1:14 PM UTC
Hi @surbhi, you can try to use a ParameterFetcher to fetch the connection file and pass that parameter as an attribute instead of as a publish parameter in the FeatureReader.
