How do I specify a specific installation or version of FME to use in my batch file?
  • Nov 24, 2016 10:25 PM UTC
  • 98 views
fmelizard
Forum|alt.badge.img+22
This Knowledge Center article explains the syntax and use-cases, but 'fme' always gives me a version of FME I don't want!
https://knowledge.safe.com/articles/1384/fme-batch-processing-methods-1.html
Best answer by erik_jan
Another option that I used before is making a copy of the fme.exe application and rename that copy using the version number (e.g. fme2015.exe, fme 2016_1.exe) and use that in the batch file.
rylanatsafe
Forum|alt.badge.img+14
  • Nov 24, 2016 10:28 PM UTC
To launch the workspace with a specific version/build of FME using a batch file, replace 'fme' with the full path to the fme.exe application located in the installation folder of the version/build you would like to use!
e.g. C:\\apps\\FME\\fme.exe C:\\Downloads\\workspace.fmw
erik_jan
Forum|alt.badge.img+26
  • Nov 25, 2016 4:42 AM UTC
