How do I generate unique ids from existing and future object ids ?
  • Mar 9, 2018 4:16 PM UTC
  • 192 views
How do I generate unique ids from existing and future object ids within a 50000 range and 30 diffattributeerent s within a 50000 range.There are 30 different attributes and each should be within a set block; i.e pt=10000; rt=20000;st=30000, etc. These are within an ESRI File GDB.Please help.
@useytkaziev
danilo_fme
Forum|alt.badge.img+58
  • Mar 9, 2018 7:51 PM UTC
Hi @charlesbanks,
I believe that you can compare these values ( if has a not unique ids ) with a temporary data, for example Excel file using the transformer FeatureWriter. After a transformer Tester to compare the Ids from you Reader ( Input ) and your temporary XLS.
Thanks,
Danilo
How do you set them apart in blocks? These are values within a File Geodatabase (Object IDs).
gio
Forum|alt.badge.img+15
  • Mar 12, 2018 3:55 PM UTC
fid in shapes are just like row numbers. Delete a row and all is reset.
Generating unique id's from those will only be valid as long as you don't rerun the generation based on these fid's.
If you want to partition your data based on attributes, create a group by attribute based on the required attributes. Usually by concatenation.
GroupBy= @Value(pt) @Value(rt ) @Value(st) @Value(etc.)
Or if string is getting bit long, by using a counter to id each attribute and create Group By of those values
Use the group by value in a counter.
