How do I automatically set/read data type when using SQLCreator and reading data from PostgreSQL/PostGIS database? My FeatureWriter (to FFS) has all the data types set to varchar(200).
  • Oct 23, 2020 11:19 AM UTC
  • 96 views
robert.wright
I have a workspace with several SQLCreators that executes a query to retrieve data from a postgreSQL/PostGIS database.
After some manipulation of the data I then am sending it to a FeatureWriter (to FFS) and all the data types are defined as varchar(200) when many of the original attributes from PostgreSQL/PostGIS are of different data types.
I have looked through documentation, searched in community and it appears my only option is to change/switch the featurewriter from "automatic" for Attribute definition to "manual" and define everything by hand. It doesn't appear that "dynamic" option will do what I need either as some of the original attributes being pulled for the PostgreSQL/PostGIS database have been renamed. (i.e. select attr555 as display_name from mytable)
Is there another option than manually changing the data type for each feature within the featurewriter?
  • Nov 6, 2020 8:36 PM UTC
Hello !
You can import your database schema in the featurewritter. Hope that helps.
